taking off valve springs
hey i blew my engine and now im trying to take the last valve spring off the number 7 cylinder and the piston isnt holding compression. so does anyone have any suggestions about how to take it off withou pulling the head?
i bent the connecting rod also so i cant turn the engine. im putting the engine back to stock cuz it is still under warranty so im going to have chevrolet put in a new engine
Break a spark plug and hollow out the threaded part and braize an air hose attachment too it, put it in the spark plug hole and hook up compressor. I think you can actually buy a part that will do this check parts store. I just made my own though.
True, but as logn as it isnt a complete and total loss, having the cylinder see a constant flow of pressurized air may be enough. It really just depends on how bad the piston/cylinder is damaged.
