shifting to hard or fast with the stock shifter will it break trans
Old 11-30-2007, 09:46 PM
BigRich954RR's Avatar
Default shifting to hard or fast with the stock shifter will it break trans
Was told that shifting to hard or fast with stock shifter would cause the trans to ware out or break. If true what shifter to put in to replace it. this will be for a 06gto that does mostly street with some hard track days.
Old 11-30-2007, 10:40 PM
Jared 3870's Avatar
The T56 has internal stops. However if you want to go with the PRO 5.0, it has stops on the shifter base as well, so there shouldn't be a problem.
Old 11-30-2007, 10:55 PM
thesource's Avatar
I'd definately get a good shifter if you plan to beat on the transmission .
