Rear 02 sensor question (pertaining to ORY)
I'm in Ca and want an ORY, but I also have to pass emissions. Here's my question. I'll have to get car tuned to delete the rear 02 so that it doesnt throw any codes. For smog tests I will be putting my stock y-pipe back on the car, but will it fail because the rear 02's will be turned off??
is it an OBD inspection? where they hook up to the OBD connector and check for codes? I have my'n turned off..and my'n passed..so i'm assuming you'll be okay. Do you have anything else deleted?
it'd just be the rear 02's that are deleted. I told my tuner to keep the EGR and AIR on so I can pass smog, but last time he turned those off as well, so I don't even really know to be honest with you...
