K+N Valve Cover breather part #????????
Re: K+N Valve Cover breather part #????????
What's wrong with your PCV system? If you use the breather, get ready to start finding a thin, hard to remove oil film on the inside surface of your windshield . . . and with the windshield rake that these cars have, it will be a PITA to clean it off, ask me how I know.
The Bull
Take a look at using the Moroso recirculating breather instead. It doesn't vent oil to the outside. I've not had one drop of oil anywhere using one of those. I'm not sure how to retrofit it onto the stock cover, but the two piece versions come with a 1.25" bushing that you use to press into the valve cover. Then you can unsnap the upper breather to fill the car with oil.
