How do I remove the rear window defroster lines?
Re: How do I remove the rear window defroster lines?
ive thought about this to. when tinted black the ugly oranage lines show up bad.ive rear defroster is a options on maros so that makes me wonder if some back windows are solid clear. i havent seen any. as for removing your lines i wouldnt.
rear defrost was an option.
As far as i know they are glued on. Try using a razor blade to get under the grid. I don't know if there will be any phantom lines left thou?
any way to peel them off or something?
In all seriousness, they should come off with a razor blade. They're just little aluminum strips.
