t56 synchros?
t56 synchros?
hey guys I have a 2000 ta with a t56 and gears 1,2 and 3 I get a loud whine and it chirps through those gears when I go to shift to them but I only get the whine when my foots on the gas. My clutch and tranny are both stock and I was told it could be my synchros but I'm not sure any suggestions would be great thanx.
is it hard to get into gear? does it grind when you shift? my synchros went out when car was under warranty. They replaced 2nd, 3rd and 4th sychros. never heard a whine just grinding gears. So I would say it might be something else if it is not grinding and hard to get in gear. good luck hope you figure it out.
It grinds some times but it is very difficult to get into gearsometimes. I have a stock shifter but I just got a pro 5.0 i did the drill mod and that helped a ton shifting at high rpm's I just can't figure out the whinning ive had many people asked me if my car was supercharged could it be one of the bearings?
