i need advice on a package.
Old 12-06-2007, 05:02 PM
nick1ta's Avatar
Default i need advice on a package.
i have about $5000 to spend on a nice H/C package. My car is a 2000 Ws6 M6, and is not my DD so I would like an aggressive setup if it's doable in my price range! My current mods are FLP LT's, ORY, Borla cat-back, PP throttle body, Lid, shocks and springs, drilled and slotted roters, free mods, Tune, pro 5.0, drag radials, and other stuff i'm sure I am leaving out. I also and going to upgrade my intake.
Any suggestions of heads, cam, and intake would be much appriciated.
Old 12-06-2007, 05:43 PM
nick1ta's Avatar
Also, the car is going to mostly be drivin on the street with little track time. I would like to see 450+rwhp. Oh yea..........might add a little spray for some real #'s.
Old 12-06-2007, 09:14 PM
transamfreak01's Avatar
ms4 with some afrs w/ a ls6 intake. make some good power
Old 12-06-2007, 09:15 PM
mrhzk35404's Avatar
get your self a 12 bolt or 9" rear first.
Old 12-07-2007, 06:13 PM
nick1ta's Avatar
well, that is in the plans. But i would like to do H/C/I first! anyone else?
Old 12-07-2007, 06:29 PM
Dokken's Avatar
What is a ms4???
Old 12-07-2007, 06:38 PM
nick1ta's Avatar
ms4 is a SWEET cam that makes very nice power!
come on people! I know this is asked all of the time, but I need some real advice.
Old 12-07-2007, 11:12 PM
nick1ta's Avatar
ttt
ttt
Old 12-07-2007, 11:23 PM
98RedZone's Avatar
Custom cam from PatrickG with AFR heads and LSX intake. He has made the most power out of a 346,
Old 12-08-2007, 12:46 AM
nick1ta's Avatar
yea......but, will be able to get the power i want within my 5k budget?
Old 12-08-2007, 10:28 AM
98RedZone's Avatar
Just some rounded up numbers
AFR Heads 2400
Cam+extras 600
Fast 90 875
90 mm TB 375
That leaves 700 for a tune and miscellaneous stuff
read this
https://ls1tech.com/forums/generation-iii-internal-engine/732392-recipe-500-rwhp-heads-cam.html
Old 12-08-2007, 10:44 AM
3rdgentug's Avatar
98 redzones pretty close w/ his numbers, a lil high even if you check w/ sponsers they have discounts all the time.
i basically got everything in my setup done for less then that but i didnt go w/ such expensive heads. i also used the FS section here for alot of my parts.
biggest thing is shop around vendors once you decide what you want, they will work w/ ya in your price range n goals for the car.
