853 Heads Ms3 Cam And Boost?
Old 12-06-2007, 07:56 PM
Jpr5690's Avatar
Default 853 Heads Ms3 Cam And Boost?
How Much Boost Could I Run With 853 Heads And A Ms3 Cam.. My Cr Is Approx 10.9 (i Think)
Also Isnt A Cam Like This Too Big For A Efficent Blower Setup?
Old 12-06-2007, 08:22 PM
gametech's Avatar
I assume you are referring to the T/A in your sig, which means you are asking about a centrifugal blower. While perhaps not "the best possible", centrifugals tend to work pretty damn well with high compression and big N/A cams. I wouldn't sweat it too much. Just make sure you have a VERY good flowing exhaust.
Old 12-07-2007, 06:37 AM
98Z28MASS's Avatar
D1SC at 7-8 Psi...you will be loving it
Old 12-07-2007, 07:48 AM
Jpr5690's Avatar
Does Straight Pipes Count As Good Flowing ...
Also Dam Mabye I May See A Blower In My Future (after The 408 And N20)
Old 12-07-2007, 09:38 AM
registered user
ScreaminRedZ's Avatar
Damn, I thought that my cam was not blower compatable, but if the MS3 will work, then mine definitely will. Hmm....
Quick Reply: 853 Heads Ms3 Cam And Boost?
