FS: Fresh LT1 heads
FS: Fresh LT1 heads
From a 96 LT1.
The heads have been freshly built by Wayne Calvert in Denton. They are complete with fresh seats and valves, angle cut valve job, new LT4 springs and locks.
Unfortunately, I can't use them. They had been cut previously and he cut another .015 off to get them flat. That would put the compression ratio to 11.2 to 1 which is over the limit of the rule set I run under.
The combustion chambers are measured at 52cc.
These will bolt right on and you get a nice bump in compression.
Looking for $450 plus a set of good cores.
Heads are located in Ft. Worth
