15x10 TTII's Backspacing?
OK i've been trying to make a list of things to do this coming year. I want to keep a uniform look even on the "race" tires. I've found the size i want, now i just need to know what backspacing, etc. they need to be. Will 15" rims clear the caliper/rotor?
I'll be running a M/T DR 295/65-15 w/ a 9" rear.
with stock brakes I doubt they will fit. Prostars and other drag rims that are made to be super light track only rims won't even clear without tons of grinding. So a street rim in a 15" size would probably not fit at all. Regardless though if anyone wants to give it a shot the Backspace would have to be the same as any other drag rim to fit correctly. so for a 15x10 you would need a 7.5" BS.
