What is required....(transmission related)
To fit an overdrive 5 or 6 speed manuel transmission into a 64 A-body, specificly a 64 oldsmobile with a 330 V8. The car has a 4 speed muncie right now and im interested in fitting it with an overdrive transmission. Which transmission you ask? Im not sure, which one will be best?
I have read about T5's being weaker, but the 330 I will be putting it behind is not that powerful. I dont know much about the t-56 or any other modern overdrive for that matter. Do any of these modern transmissions have a way to hook up a mechanical speedometer?
Thanks for the informatioN!
James
James
for the t56 you must use an adapter for the speedo and have to rig an hydraulic clutch as well.
If you go to teamchevelle.com youll find quite a few guys running t56's on these cars. It would be a good place to ask questions.
