Meth ?
Old 12-18-2007, 11:13 AM
ss01layinwheel's Avatar
Default Meth ?
Just got my Snow Perf meth kit. Got a couple questions before i put it on and go tuning.
I have been hearing washer fluid that is rated to -40 degrees or low is the way to go, is this the case? I have NGK tr6 plugs in the car now. should i go colder or is that not neccesery? Any other input is appreciated
Thanks,
Jim
Old 12-18-2007, 11:38 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Washer fluid mix is not consistent, and a poor substitution for meth. I'd run meth only- especially since you are going to tune for it!
Old 12-18-2007, 01:04 PM
BadgeZ28's Avatar
I would be interested were you mount the pump and reservoir on your install.
Old 12-18-2007, 01:15 PM
Adam98Z's Avatar
I am not sure how feasible it may be in an f-body, but when I was doing w-body's sometimes we'd relocate the battery to the trunk and put the reservoir in its place.
Old 12-18-2007, 02:50 PM
JAvenger007's Avatar
I cleaned out my washer fluid resevoir and tapped it for the meth.
Also, Don't use windshield fluid as a substitute.
Old 12-18-2007, 03:19 PM
I'm mounting it on the floor behind the driver's seat. easy to hide and no one sits back there
Old 12-18-2007, 05:36 PM
Websy21's Avatar
This is what I thought of and will probably do so too.
Quick Reply: Meth ?
