How to remove the wiper motor, and linkage?
Old 06-28-2003, 07:12 AM
needmoremoney's Avatar
Default How to remove the wiper motor, and linkage?
Just as the topic says. I tried this yesterday. On each arm there is a flap to remove, and under that there is a nut. I removed the nut, AND CANT REMOVE THE ARM! Are they pressed in? Anyone ave any good write ups on this?
Old 06-28-2003, 11:18 AM
Tom the roofer's Avatar
Default Re: How to remove the wiper motor, and linkage?
There are rubber caps. 3 of them I believe. These ar covering a ball and socket type connection. Take a screw driver and position it at the base of the rubber cap and pop the ball and socket fitting apart. There you have it.
Tom
Quick Reply: How to remove the wiper motor, and linkage?
