wont bleed after LS7/LS2 swap (damn mccloed master)
Old 12-23-2007, 10:20 PM
weaponZ's Avatar
Default wont bleed after LS7/LS2 swap (damn mccloed master)
I read every write up.I bench bleed the master.I went out and bought a mity-vac.I replaced the seal on the master.What else can i do?
The culprit seems to be the mccloed master cylinder.I bought it used from a friend.It had been sitting up for a few months and got gunked up.We pulled it apart and cleaned it up.Finally i was getting fluid out the shrader valve when i would bench bleed.I put it on the car for the 50th time and put the mity-vac on it right away.Ther were some serious bubbles comming threw the line,but i noticed i was loosing a little pressure and had to keep pumping after a few mins.Is that normal?
What next?
Old 12-23-2007, 10:23 PM
Snyper's Avatar
sounds like a leak somewhere else..is the line in good shape?
Old 12-23-2007, 10:31 PM
weaponZ's Avatar
Maybe i will go buy another steal braided line to goes in the transmission.Any idea what it cost?
Old 12-24-2007, 02:31 AM
BarneyMobile's Avatar
I kno the dealer wont sell you just he line, the line comes with a new master cylinder.
Old 12-24-2007, 01:32 PM
Snyper's Avatar
try hinsonsupercars.com they buy the line and modify it for use with the RX7 setup(thats where I got mine) maybe he can sell you a new unmodded one.
Old 12-24-2007, 04:23 PM
bigsticksupra's Avatar
Mcleod makes a stainless line without restrictions that you can buy
Old 12-24-2007, 04:30 PM
The PAT WS6's Avatar
all it is. is your master ur not bench bleeding it right at all
Quick Reply: wont bleed after LS7/LS2 swap (damn mccloed master)
