02 sensors
Old 12-26-2007, 12:14 PM
zmanx's Avatar
Default 02 sensors
How many 02 sensors does a 99 z28 have ? I havent had much time to get under it lately. Also im throwin a code for an 02 sensor and it says Bank 1, which one would be bank 1 ?
Old 12-26-2007, 12:19 PM
Levman74's Avatar
There are 4 O2 sensors, 2 pre-cat and 2 after-cat, Bank one is on the left side.
Old 12-26-2007, 12:24 PM
2001NBMZ28's Avatar
If you're stock you have four. Bank 1 is drivers side, Bank 2 is passenger side - and Sensor 1 is precat, Sensor 2 is post cat. The code will tell you which one it is. 02 codes always specify Bank __ Sensor__.
Old 12-26-2007, 12:30 PM
zmanx's Avatar
Thanks guys, thats exactly what I needed to know.
Old 12-26-2007, 12:47 PM
2001NBMZ28's Avatar
Don't buy any without posting the code first - could be a symptom of something else going on, for example the post-cat sensors monitor the efficiency of the cats...you may already know, just don't want you buying one you don't need.
Old 12-26-2007, 01:10 PM
zmanx's Avatar
The code discription does say bank 1 number 1, so that would be drivers side pre cat , is that right?
Old 12-26-2007, 01:24 PM
2001NBMZ28's Avatar
Yes, bank 1 sensor 1 is the precat sensor, driver's side.
