Removing PCM?
Removing PCM?
Going to have the computer tuned, and wanted to know if there are any hidden tricks about taking it out or is it just like it looks?
Re: Removing PCM?
Just like it looks. Loosen the 7mm bolts from the connectors and pull the connectors. The bolts won't come out of the connector, they're retained to it. Then remove the two bolts that are right there holding it down.
