How to wire up my LS1 coolant temp to LT1 dash?
Alright, I have the Coolant Temperature feed to instrument cluster wires connected @ C220, but I think the reding is different for both sensors so the LT1 gauge wont read it. The only thing I can think of is to run 2 coolant temperature sensors. The one on the driverside being the 98 coolant temp sensor and the pass side have a 96 LT1 coolant temp sensor. Would this work, wiring the 96 Sensor to the gauge only and the PCM using the 98 Sensor? How would I wire the 96 sensor up? Thanks for any input.
i have no idea about you question but i was wondering how hard it was to change from a LT1 to the LS1? im about to buy a 96 project car and i want to put an LS2 or stocker in it.. i was just wonder what all went into you project
not hard at all, the basic things youll need is:
LS1 rack and pinion & knuckle
LS1 K-member
97 Vette Fuel Rail
LS1 Engine & Transmission w/ Wiring and PCM
Then wire it all up.
LS1 K-member
97 Vette Fuel Rail
