Used fast 78mm intake for $400-$450 ok??
Old 01-05-2008, 05:28 PM
04goatman's Avatar
Default Used fast 78mm intake for $400-$450 ok??
If i can pick up a used fast lsx intake for around $400-$450.00, Is it woth it & should i get it ? currently i am running ls6 intake on 04 gto.
Old 01-05-2008, 05:33 PM
1badA3Z's Avatar
There have been a few 90mm fast on here lately,between 500-700,i wouldnt waste my time on a 78mm if you already have an ls6,jmo tho!
Old 01-07-2008, 09:17 AM
radkon's Avatar
The 78 MM FAST and 90 MM fast are only about 3~5 HP different according to research Tony has done so if you can pick up a 78 cheap I'd go for it. I did! I gained 10 HP from the swap.
Old 01-07-2008, 09:33 AM
Hugger's Avatar
That is less than I paid for my Fast 78MM. Mine is hogged out in the front to fit an 85mm throttle body. I say go for it.
Josh
