clutch master resevoir
Old 01-06-2008, 12:43 AM
zrocket_99's Avatar
Default clutch master resevoir
i should know this but i knew to the hydrolic system on the clutches. you know the black rubber bladder in the mc resevoir. when i am checking the fluids or putting more fluids in the resevoir, do i take the rubber bladder out and fill the resevoir up and then put the rubber bladder back in or do i pour the fluid in the rubber bladder? thanks in advance
Old 01-06-2008, 12:59 AM
ski23's Avatar
take rubber out then fill. make sure you dont over fill it tho. once you put the rubber back in the fluid is gonna rise.
Old 01-14-2008, 11:02 PM
zrocket_99's Avatar
alrighty thanks man
Old 01-14-2008, 11:48 PM
Texas 02 Z28's Avatar
I dunno if you do this or not, but when it's black, you should change the clutch fluid. It takes 5 minutes, and it feels like a new clutch everytime you change it. It's sweet.
