few questions about cam swap and adjustable rr's...
Old 01-06-2008, 09:00 PM
jshelton2006's Avatar
Default few questions about cam swap and adjustable rr's...
ok, im doing my MS4 swap, wondering what gears to go with. ive been planning on 410s but just wondered if i should go lower than that. not DD, dont care about mpg, just want as much performance as possible but still good driveability. also i ordered HS 1.7 adjustable roller rockers, how much adjustment do these give? i know i obviously still need the right length pushrods, but just curious as to how close they need to be...thanks for any replies!!
Old 01-06-2008, 09:04 PM
also, im doing cam, stock heads milled w .040 gasket for 11.5:1 CR, rr's, tb spacer, clutch, rod bolts, 160* t-stat, ported tb, flycutting, e-cutout, dyno tune...i already have full bolt-ons minus EWP, and car is an 02 ss M6. my goal is to hit 425+ rwhp. think i'll get it???
Old 01-06-2008, 10:52 PM
BOWTIE's Avatar
As far as I know, the Harland Sharps ar NOT adjustable.
Old 01-07-2008, 11:41 AM
they make both adjustable and non-adjustable...i got them from speed inc
Old 01-07-2008, 11:48 AM
vettenuts's Avatar
Do they come with the pushrods? If not, there is a way to determine the correct pushrod length/adjustment. I worked mine out with the Cranes on the workbench by obtaining the best wipe and then measuring the adjustment nut position such that when I put them on the car I knew where to set the rocker to measure for the pushrod.
Where is the adjustment nut on the YT's, it is at the stud or at the pushrod?
Old 01-07-2008, 12:46 PM
they don't come with pushrods, but the adjustment nut is at the pushrod...
Old 01-07-2008, 02:46 PM
vettenuts's Avatar
So the fulcrum bolts down hard and the preload on the lifter is set by the adjuster? Then you can check the wipe, and once you have that measure for the pushrod.
