outet pipe sizes for LM & magnaflow
Old 01-07-2008, 12:12 PM
Twigs's Avatar
Default outet pipe sizes for LM & magnaflow
I need to know the outlet size of SLP LM 1/2(assuming its the same) and magnaflow. I have some tips that are 2.6 inlet that I am going to put on them.
BTW, the magnaflow tips are really long, can I fit regular sized tips(corsa clones) on it or does the pipe need to be extended for it to fit?
Old 01-07-2008, 12:31 PM
'00_Z's Avatar
The tailpipe outlet is 2.5" on the LM1. And if you want to replace the "cannon" tips on the Magnaflow you will have to extend out the pipes to use the Corsa style tips.
Old 01-07-2008, 12:41 PM
Twigs's Avatar
thanks. LM2 is exact same size as LM1 right? and thats what I figured for the magnaflow
Old 01-07-2008, 02:11 PM
Raise's Avatar
correct...with the muffler being the only difference between the two systems
