Needed: LT1 Clutch Master Cylinder U-Bolt
Does anyone have a clutch master cylinder u-bolt? This thing is special order from GM and is going to take 3 weeks to get. FYI, this is the bolt that holds the master cylinder to the firewall and pedal assembly.
I'm also looking for the spacer that goes on the bell housing for the slave cylinder.
Thanks,
Kyle
Thanks,
Kyle
couldnt you use 2 bolts with nuts and washers? the U-shaped bolt is kind of a joke, doesnt really do a whole lot in there. I have a few of those at home layint around, the problem is i wont be back there for a few weeks. sorry
Yeah I could but once motor is back in it will be pretty tough to get a wrench back under the brake booster if I ever need to take it out again. Thanks for checking though. I think I may have found one local.
Kyle
Kyle
