4L60E Cooler fittings
Old 01-09-2008, 04:30 PM
55LS1's Avatar
Default 4L60E Cooler fittings
I'm trying to find out what thread the tranny cooler provisions are on a
4L60E. I'm almost done with my 55 conversion, one of the last things I need is to hook up my tranny cooler. Does anyone know what AN fittings to run that will thread right into the tranny? Thanks for any help or advice!
Old 01-09-2008, 04:38 PM
jomomma's Avatar
im sure there is a fitting for that. i went the harder route. i cut and flared the hard lines, then hooked up my -6an fittings.
Old 01-09-2008, 04:43 PM
forcd ind's Avatar
LS1Tech 10 Year
ATI trans sells the fittings you need, they are listed as 1/4-18, which is not a pipe thread, they are straight threads, although people jam pipe threads in there
they have them in #6 or #8, screw right into the case, not the factory fitting
www.atiracing.com
Old 01-09-2008, 05:42 PM
55LS1's Avatar
Thanks for the tip, I will give them a call tomorrow!
www.atiracing.com
Old 01-10-2008, 01:27 PM
55LS1's Avatar
Just ordered the fittings! I would have never found those! Thanks!
www.atiracing.com
Old 01-18-2008, 10:18 AM
55LS1's Avatar
Got the fittings from ATI yesterday, worked perfect!
