Insight needed........
Ive had a 383 sitting around for a while now and i think im gonna use it. Its already forged, compression with stock heads should be around 8.8:1. Was built to go in a C10 truck with a roots and carb setup. Anywho. Im thinking of running twins. Ill be honest im new to turbo's, i read and pick up alot but im really a nitrous man myself. Heres the good part i want to be completely different. I like the idea of the STS kits but.........what if. You mounted both turbos under the back seats where people usally mount mufflers. Cut the floor pan out and raise the floor up to make room. Keep the cold side of the turbos to the out side and run up on each side, combine them in the intercooler and then to the TB. But run only turndowns on the exhaust side. I know you will hear the things spool a long way away, but its only a track car. The cam not sure about. Probaly a custom grind. Intake is a Victor Jr with elbow and I need a 90mm TB. Transmission will be a 400 turbo with around 4000-4500 stall, shifting at 7500-8000. Rear is a 12-bolt and probaly change gears to 3.08. Im not real good at picking the right size turbo's. Other than that i can handle everything else. Insight..........................:
