MS3 grinded advance?
Old 01-17-2008, 08:54 AM
Jeff M's Avatar
Default MS3 grinded advance?
Anyone running a 113+2? I would really like to run the MS3, but would like the power to peak a little earlier so I don't have to rev my stock bottom end to 6800.
Old 01-17-2008, 09:25 AM
s346k's Avatar
then you better knock down the duration, adding advance isn't going to lower the peak enough to make a difference. seeing that you'll still be within 1-200 rpm of the original peak (with less hp), and will theoretically make peak power longer..that you won't even use.
Old 01-17-2008, 09:50 AM
Jeff M's Avatar
Well damn, I need to do a little more research then. Thanks for pointing that out.
