Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
FS: Complete T56 Swap for use with an LS1 in a Fox Body Setup, in Michigan
Old 01-18-2008, 09:39 AM
PaxNovi 5.0's Avatar
Default FS: Complete T56 Swap for use with an LS1 in a Fox Body Setup, in Michigan
Goin in a completely different direction, so am selling all of the following parts as a package.
Comes with all parts and bracketry to use a T56 for use with an LS1 in a Fox Body swap. Basically makes for a complete bolt in setup without the headaches of fabrication. Transmission originally came out of a '99 LS1 Camaro. Bought the whole package out of another Fox Body/LS1 swap vehicle, so the entire setup has been in and already proven to work in a Fox.
Only thing purchaser would have to do is slightly modify the Fox trans x-member.
-T56 & Bell(58,000 miles)
-Textralia OZ700 Clutch/Flywheel Assembly(1,800 miles)
-Moly Custom Driveshaft(Mates T56 with 8.8 rear)
-Brand New Pro 5.0 Shifter w/ 6 Speed shift ****
-Tilton Master Cylinder Setup
-Slave Cylinder and Resevoir
-Braided lines
-All bracketry to make work in a Fox
-Turbo Coupe Clutch Pedal
$2500 Firm
Would rather not freight, would prefer pickup. IM, PM, or Post with any questions. Thanks
Old 02-20-2008, 01:11 PM
blownmiata's Avatar
PaxNovi - do you still have your trans?
Old 02-23-2008, 04:01 AM
Sorry, I just saw there was a reply to this thread. To answer your question though--Yep, everything is still for sale.
Old 02-27-2008, 05:47 AM
Bump, should have pics shortly.
Old 03-20-2008, 12:58 AM
Default Pics
Finally got a new camera, and some pics! Click to see larger versions.
Old 03-22-2008, 02:12 AM
To the top
Old 03-23-2008, 10:20 PM
Bump.
To address all PM's, I am not looking to part out at this time.
