Ford 9" + 3.5" alum. DS help
Old 01-24-2008, 09:29 PM
WS6 GreeN's Avatar
Default Ford 9" + 3.5" alum. DS help
I have a couple questions. First off, is it possible to overtighten the four nuts that hold the u-bolts on at the rear end? Second, where can I buy some more of those u-bolts? TIA!
Old 01-24-2008, 11:44 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
yes, the u-bolts can be overtightened. they will normally strip off the threads if done so.
if it is a 1350 series u-joint, the part # is 330-10 from Precision U-joint. i've had good luck getting them from o'reilly auto stores
Old 01-25-2008, 01:04 AM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
If u-bolts are overtightened you can oval the u-joint cups and that will cause premature failure.
Old 01-25-2008, 04:37 AM
EPP
EPP's Avatar
Question
Are you the guy we have more u bolts going out to? Bob
