Anyone got a good way to get a tight shiftknob off?
Old 01-26-2008, 02:51 PM
FSUNole17's Avatar
Default Anyone got a good way to get a tight shiftknob off?
That mother F'r is on there TIGHT. It is the C6 shiftknob on a LSS. Anyone got any suggestions on how to get it off? Thanks
Old 01-26-2008, 02:55 PM
Phoenix 5.7's Avatar
are u replacing it or just want to take it off? if ur replacing it, u could use a pipe wrench, but that will probably mess it up a bit. if ur takin it off and keepin it, do u ahve a strap wrench?
Old 01-26-2008, 04:25 PM
FSUNole17's Avatar
I am wanting to change shifters so just takign it off, and no, i dont have a strap wrench
Old 01-26-2008, 04:57 PM
wrencher
wrencher's Avatar
Strap wrench is the best thing with out destroying the ****.
If you dont care anything that will grab it will work to twist it off.
Old 01-26-2008, 05:01 PM
u also could try wrapping it in some grip tape to get a better hold on it with your hands.
u might be able to put a chuck of rubber between the **** and use a pipe wrench and not damage the ****
Old 01-26-2008, 05:46 PM
RAMPANT's Avatar
You could try using a hair dryer.
I always noticed that my factory one would be loose on a hot day, then unmoveable on cold winter day.
Just a thought.
Old 01-26-2008, 07:36 PM
FSUNole17's Avatar
Thanks fellas, I will give it a shot
Old 01-26-2008, 07:54 PM
renxwar's Avatar
Depending on if your car is still driving, I had a hard time getting my stock one off.. so what I did was whenever I got to a stop light, I'd twist it with all my might. After a few stop lights, the constant twisting loosened it up enough for me to get it off fully. Plus it wasn't me sitting in my car for 45 minutes trying to twist it off. Worth a try.
Old 01-26-2008, 09:41 PM
LSX Mechanic
Damian's Avatar
Wrap it with a thick towel and put a pair of channel locks around it.
Old 01-26-2008, 10:47 PM
LS1TECH.com Sponsor
WS6store.com's Avatar
This is exactly what we do as well. Works every time.
__________________
WS6Store.com | Sales@WS6store.com
F-Body Performance Parts | 1-877-232-9701
Old 01-27-2008, 12:30 AM
slayerized6's Avatar
i give a +1 to the hairdryer. hairdryer has been my best front the best few days
Old 02-10-2009, 06:10 PM
integraxtc's Avatar
damn, I'm trying to take mine off, and it twists but it doesn't move up.
Twist left right? LOL.
Old 02-10-2009, 06:25 PM
4WOFURY's Avatar
They're reverse threaded.. Looks like you need a whole new stick.
Just messin, have you tried pulling up while your unscrewing? The center screw piece may have detached from the ****.
Old 02-10-2009, 06:56 PM
integraxtc's Avatar
yeah, I tried lifting up. I can twist it, but it's hard to twist.
Old 02-10-2009, 07:06 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
YUP.....
Old 02-10-2009, 08:07 PM
integraxtc's Avatar
I just went and tried again, lifting and unscrewing.
I think the center screw piece detached from the **** itself.
How do I take it off now?
Now I'm stuck. I'll probably just leave the damn thing (I wanted to replace the boot bezel for the one made of wire. I'll probably deal with it when I switch to my short shifter.
Old 02-10-2009, 08:09 PM
NHRAMAN's Avatar
Unhappy
PROBABLY BROKEN NOW....shoulda used towel and 'locks...lifting screwed something up.....
Old 02-10-2009, 11:38 PM
4WOFURY's Avatar
Different poster than OP. His already was spinning.
If you have the **** off and just have the screw on part stuck on the stick, take a pair of channel locks to it and get it off. Past that, you're on your own lol.
Old 02-11-2009, 08:03 PM
integraxtc's Avatar
lol. No, the **** itself is not off. I tried just lifting it up, in hopes that the threaded base would stay behind on the stick, but no.
Old 02-11-2009, 08:38 PM
2thousand2's Avatar
I have had to destroy the **** on two different cars to get it off. I have a spare SLP leather **** for this reason lol.
Quick Reply: Anyone got a good way to get a tight shiftknob off?
