Sponsored by: DashLynx
Which one is better????
Old 07-08-2003, 04:40 PM
TMar99Z28's Avatar
Default Which one is better????
Ok, I posted a question similar to this yesterday and I really need some help. I'm down to deciding between the Suncoast Creations SS hood or the American Sportscar Design SS hood. Someone please help me. Also how does the American Sportscar hood use the stock air box instead of the airbox that suncoast uses?
Old 07-08-2003, 07:55 PM
PR Director
Deech's Avatar
Default Re: Which one is better????
The ASCD hood is molded from a OEM hood, so you get that OEM look but after market product. The SCC hood has a higher hood scoop I believe and the bottom of the hood is cut to seal to their custom intake. The ASCD hood could use the SCC intake but it won't gain as much as it would with the SCC hood because it is open on the bottom to fit the intake. Choose which ever one your want, it comes down to what you like. If you want the stock look go for the ASCD if not go for the SCC. Hope this helps a little.
Old 07-08-2003, 10:32 PM
TMar99Z28's Avatar
Thanks for the advice, I went ahead and ordered the ascd hood earlier today.
