anyone in se missouri area with atap or similar??
my car occasionally throws o2 slow response codes and i am going to seal around o2 sensors to see if that fixes that but sometimes the engine light flashes when car gets around 75mph and other times it will go a lot faster with out flashing, and there is no code stored, so i was wondering if anyone has anything that can be hooked up to the car while running down the road to see what is going on when light flashes, if not what do you guys suggest using, with atap do you have to have a laptop or will it store info and replay it when hooked up to pc?
11 Second Truck Club
Re: anyone in se missouri area with atap or similar??
I am in the SEMO area. Where exactly are you at? I have never seen your car around 'cause it sounds like a real eye catcher and I would remember that.
