Autometer Gauges for sale "Brand New"
Part 3301 Autometer Boost Gauge brand new in the box.
Sells for $47.95 + shipping from Summit.
Auto Meter Sport-Comp
Gauge Type: Boost/Vacuum
Gauge Range: 30 in. Hg/20 psi
Gauge Diameter (in): 2 1/16 in.
Gauge Diameter (mm): 52.00mm
Sweep: Full sweep
Sending Unit: Mechanical
Gauge Face Color: Black
Gauge Number Color: White
Pointer Color: Red
Bezel Color: Silver
Liquid Filled: No
OEM Replacement: No
Sending Unit Included: No
Quantity: Sold individually.
Gauge Series: Analog
Footnotes: 27 - Includes 6 ft. tubing.
32 - Includes T-fitting.
Gauge, Sport-Comp, Fuel Saver Vacuum, 30 in. Hg/20 psi, 2 1/16 in., Analog, Mechanical, Each
$45.00 local.
Part 3327 Oil Pressure Gauge
Summit Sells this for $53.95 + Shipping.
Gauge Style: Auto Meter Sport-Comp
Gauge Type: Oil pressure
Gauge Range: 0-100 psi
Sweep: 90 degree sweep
Sending Unit: Electrical
Pointer Color: Red
Bezel Color: Silver
Liquid Filled: No
OEM Replacement: No
Sending Unit Included: Yes
Footnotes: 22 - Includes 1/8 in. NPT sender.
23 - Air-core meter movement.
33 - Includes 1/4 in. NPT adapter/fitting.
Gauge, Sport-Comp, Oil Pressure, 0-100 psi, 2 1/16 in., Analog, Electrical, Each
$50.00 local.
Part 3337 Water Temp Gauge
Summit sells this for $42.95 + Shipping.
Gauge Type: Water temperature
Gauge Range: 100-250 degrees F
Pointer Color: Red
Bezel Color: Silver
Liquid Filled: No
OEM Replacement: No
Footnotes: 34 - Includes 3/8 in. NPT adapter/fitting.
35 - Includes 1/2 in. NPT adapter/fitting.
Gauge, Sport-Comp, Water Temperature, 100-250 Degrees F, 2 1/16 in., Analog, Electrical, Each
$40.00 local.
If you take all three $130.00 for all brand new in the boxes.
858-232-1903
Dustin
Sweep: Full sweep
Pointer Color: Red
Bezel Color: Silver
Liquid Filled: No
OEM Replacement: No
$45.00 local.
Pointer Color: Red
Bezel Color: Silver
Liquid Filled: No
OEM Replacement: No
$50.00 local.
Pointer Color: Red
Bezel Color: Silver
Liquid Filled: No
OEM Replacement: No
$40.00 local.
858-232-1903
Dustin
