WTB: 98-02 ls1 m6 camaro in south florida
Like the title says. Looking for a 98-02 camaro M6 with under 80,000 miles. Color doesn't matter too much. Stock or modded is fine. Nothing out of range(south florida) since id like to look at the car in person.
I am thinking of putting my car up for sale It is a 01 red m6 SS Camaro with a built iron 6.0, edel heads, trex, fast 90/90 and every dam bolt on you can think of. I need 16000 out of it, but would be willing to remove some parts to get in your price range. pm me for futher details.
Hello,
First off the only reason I am selling this car is I have a son due on the 12th of Feb. And instead of a 2 seater coupe lsx car, I need a 4 seater Lsx car (GTO) wich I will be buying after this is sold.
I would be willing to trade for only a GTO, and maybe a lsx Truck.
The car is a: (Never Wreced)
2001 M6 Red Camaro SS
Brand New Lq9 with only 700 miles since rebuilt.
60,000 miles on the frame
Ebony interior
Engine
Tsp Edelbrock Terminator Heads with dual springs
ARP Head Bolts
T-Rex cam
Hardend Pushrods
Fast 90mm Intake
Fast 90mm TB
42lbs SVO injectors
Professoinal Product Fuel Rails
ARP Rod Bolts
Bulldawg Double Roller Timing Chain
SLP underdrive
SlP Lid
K&N filter
Cold air intake mod
Engine coolant bypass mod
Walbro 255 fuel pump
It is sd tuned, but I have a 80mm maf if you rather have that.
Supension
Pro 5.0 Shifter
Textrilla clutch
Spec Billet Flywheel + Arp Flywheel bolts
Both balanced together
4:10 Gear
Bmr adjustable tq arm
adjustable lca's
adjustable Panhard bar
Drilled slotted rotors
Painted red calipers with ss deacal
18" Boyd Blaster wheels. Highly polished
265/40/18 and 295/35/18
Exhaust
Hooker Coated 1 3/4 headers
Tsp y with a custom Flowmaster Merge collector
Slp loudmouth exhaust
Flow master Muffler
Two Cutouts
Interiour
Aem WIdeband
Corvette Dash overlays
Trans Am Bezel
Electric In car Fuel pressure gauge (dual MOunt pillar) Multicolor display.
Hurst shifter
Slp Floor mats
Leather scale 1-10 it is a 9.5 easy. I will post pics
Never had dynoed , but this thing is nice, I have no doubt that if you ride in it you will be satisfied. Never been sprayed and only went to the track once, but could not get a good enough pass to get a good time. (wheel hopping)
I do have other stuff like draglites and tires and Nitrous if wanted not included. I can also take some of the stuff off if you want it removed to lower the price.
I will post pics as time go on.
Asking 18k or best offer.
Thanks
Ebony interior
Engine
ARP Head Bolts
T-Rex cam
Hardend Pushrods
Fast 90mm Intake
Fast 90mm TB
42lbs SVO injectors
ARP Rod Bolts
SLP underdrive
SlP Lid
K&N filter
Cold air intake mod
Supension
Pro 5.0 Shifter
Textrilla clutch
4:10 Gear
adjustable lca's
Exhaust
Flow master Muffler
Two Cutouts
Interiour
Aem WIdeband
Trans Am Bezel
Hurst shifter
Slp Floor mats
Thanks
