LS6 ported head question
well guys, I bought a set of CNC ported LS6 heads. They are supposed to be TSP stage 1.5, but knowbody can confirm this for me. Regardless i got them for a good price. paid 500 shipped for them. I took some pictures and wanted to know what you guys thought of the port work? I havnt seen a cnc ported head before, so im not sure if its decent or not. I have since cleaned all the caron out of the exhaust ports. AND SORRY FOR THE BIG PICTURES. NOT SURE HOW TO RESIZE THEM?? Thanks in advance.
On every set of CNC ported cylinder heads I have worked with, the rocker embosses have been eliminated with the CNC process. GMPP, ETP, and AFR included. The only way to prevent a hole to the rocker is simple. After the CNC or hand porting process, tack the hole shut, re-port by hand, and spot face the bottom of the rocker bolt hole.
When you install the new rocker bolts, be sure to use a liquid Teflon to seal the studs so the heads don't leak. This is absolutely critical when putting them back togeather.
