Ls1 Moddified Internals , Heads , Cam Or Clean Ss Low Mile Camaro
im looking for an ls1 camaro or trans am , i have an lt1 right now , and im leaning towards another camaro but wont over look anything , i want a built engine , forged internals , aftermarket or ported heads , cam , and built trans if possible , exhaust ,suspension, and rear end are a plus also hoping it will havy aftermarket intake 90mm a plus dont want a nos car even though im putting it on , too many people dont spend the money to have it properly done unless just installed and a pass or too but be honest cause ill drive all the way there and drive all the way home with out the car if i feel the car was misrepresented ,but lets talk , really i want a bad *** camaro built and good over all cond im looking to spend around 12-14 grand but im not looking for a 12 sec car 11s will do if never been to the track thats ok we'll see what ya got ps i love black silver and white ss camaros mines maroon very hard to keep clean but no color over looked might have to sacrafice color for power or clean but let me see what everyones got , *I MIGHT BUY A LOW MILES CLEAN , WITH SOME MINOR MODS SS CAMARO SO BRING THE NOISE
https://ls1tech.com/forums/showthrea...=808694&page=3
I know you said you didnt want nitrous already on it, but i can assure you that it was a very professional install.
I am thinking of putting my car up for sale It is a 01 red m6 SS Camaro with a built iron 6.0, edel heads, trex, fast 90/90 and every dam bolt on you can think of. I need 16000 out of it, but would be willing to remove some parts to get in your price range. pm me for futher details.
https://ls1tech.com/forums/northwest-members/799397-2000-turbo-t-sale.html
has everything your asking for and then some.
price is negotiable and i would be willing to help with shipping
https://ls1tech.com/forums/vehicles-sale-lsx-powered-only/821369-new-lowered-price-13-5-a.html
I'm the 3rd owner. The N20 has all the safety equipment for an N20 car window switch, low fuel pressure shutoff, Previous owner sprayed it. I haven't even filled the bottle since I purchased the car. I drove it from Indiana to Tulsa with Zero problems.
Hello,
First off the only reason I am selling this car is I have a son due on the 12th of Feb. And instead of a 2 seater coupe lsx car, I need a 4 seater Lsx car (GTO) wich I will be buying after this is sold.
I would be willing to trade for only a GTO, and maybe a lsx Truck.
The car is a: (Never Wreced)
2001 M6 Red Camaro SS
Brand New Lq9 with only 700 miles since rebuilt.
60,000 miles on the frame
Ebony interior
Engine
Tsp Edelbrock Terminator Heads with dual springs
ARP Head Bolts
T-Rex cam
Hardend Pushrods
Fast 90mm Intake
Fast 90mm TB
42lbs SVO injectors
Professoinal Product Fuel Rails
ARP Rod Bolts
Bulldawg Double Roller Timing Chain
SLP underdrive
SlP Lid
K&N filter
Cold air intake mod
Engine coolant bypass mod
Walbro 255 fuel pump
It is sd tuned, but I have a 80mm maf if you rather have that.
Supension
Pro 5.0 Shifter
Textrilla clutch
Spec Billet Flywheel + Arp Flywheel bolts
Both balanced together
4:10 Gear
Bmr adjustable tq arm
adjustable lca's
adjustable Panhard bar
Drilled slotted rotors
Painted red calipers with ss deacal
18" Boyd Blaster wheels. Highly polished
265/40/18 and 295/35/18
Exhaust
Hooker Coated 1 3/4 headers
Tsp y with a custom Flowmaster Merge collector
Slp loudmouth exhaust
Flow master Muffler
Two Cutouts
Interiour
Aem WIdeband
Corvette Dash overlays
Trans Am Bezel
Electric In car Fuel pressure gauge (dual MOunt pillar) Multicolor display.
Hurst shifter
Slp Floor mats
Leather scale 1-10 it is a 9.5 easy. I will post pics
Never had dynoed , but this thing is nice, I have no doubt that if you ride in it you will be satisfied. Never been sprayed and only went to the track once, but could not get a good enough pass to get a good time. (wheel hopping)
I do have other stuff like draglites and tires and Nitrous if wanted not included. I can also take some of the stuff off if you want it removed to lower the price.
I will post pics as time go on.
Asking 18k or best offer.
Thanks
Ebony interior
Engine
ARP Head Bolts
T-Rex cam
Hardend Pushrods
Fast 90mm Intake
Fast 90mm TB
42lbs SVO injectors
ARP Rod Bolts
SLP underdrive
SlP Lid
K&N filter
Cold air intake mod
Supension
Pro 5.0 Shifter
Textrilla clutch
4:10 Gear
adjustable lca's
Exhaust
Flow master Muffler
Two Cutouts
Interiour
Aem WIdeband
Trans Am Bezel
Hurst shifter
Slp Floor mats
Thanks
Mine's a 12 second car. But 11's are a cam and clutch away. And with the 9" rear, it'll take whatever you throw at it. I built it as a daily driver, so a small cam (220/224/114).
2002 silver Trans Am. M6, heads/cam/headers/moser 9" rear. Daily driver.
https://ls1tech.com/forums/showthrea...643&highlight=
Also on ebay:
http://cgi.ebay.com/ebaymotors/2002-...em260210591125
Item # 260210591125
Also on ebay:
Item # 260210591125
Your location? I've got a Z28 for you I think you may be interested in, forged Mahle -2cc pistons, ARP HP rod bolts, clevite rod/main bearings/LS6 ported oil pump, double roller timing chain,polished/chamfered crank,milled stock heads, MS3 cam, comp OE lifters, 3.73 gears, 4000 stall, lid, x-pipe exhaust bullets,etc.etc,etc. The car was built for NO2, piston rings gapped for about a 150-200 shot but unfortunately I never got around to buying a kit and seeing what it would do with it. Professionally dyno tuned to drive excellent anywhere you wanna take it. It ran an 11.7, 1 out of 5 times its ever been down the track.
1999 WS.6 heads, cam, intake, stall converter, adjustable coil overs, full exhaust, sub frame connectors, tubular K member, stereo system, 83,000 miles. On drag radials it pulled a 1.6 60 foot with an 11.62 1/4 mile @ 114mph. all mods done around 60,000miles. This is NOT a race car for me, its a daily driver!! $12,500 Atl GA 770 630 7422.
