FS or trade: A4 conversion + factory seats, suspension, monsoon
Time to clean out garage and closets!
Available next week-ish, doing the T56 thing:
A4 pedal assy.
A4 crossmember
factory torque arm
steel driveshaft
2.73 gears with 50k, quiet
A4 console - no cuts or holes
TA shift **** + camaro ****
tranny with factory converter, 130k miles, mostly highway
Trans slipped once on 1-2 shift, WOT when ice cold two months ago. No slippage at all since, shifts good - I do wait for it to warm up before going WOT. Fluid is red, not brown. Has been flushed 3x, have receipts on two. Fluid speaks for itself. Can ride with me now to feel it shift and check fluid.
$500 for all
Also have now:
factory Z28 cat back - $50
factory LCAs - $25
factory panhard - $25
factory air lid - $25
cloudy headlights - $10
dimpled taillights - $10
30mm front sway bar - $25
EGR - $20
4 02 sensors - good shape - $40 each
stock 98 heads & springs, 90k - $50
perimeter bolt valve covers + 8 coil packs - $150 firm
Monsoon setup - head unit, 4 speakers, amp - $250 firm
2 blower motors - $25 each
NIB GM fuel pump/sender assembly for 98 car - $150 firm
Charcoal leather seats, good shape front and rear - no tears, still soft. Driver outer bolster is even decent. I'm **** about this and give the power driver seat 7/10, passenger and rears 8/10. conditioned every two months, minimum.
$400
Kore/UMI type C5 brake conversion brackets (steel, powdercoated black) - $75
Stuff I am looking for in trade:
Hurst leather shift **** or other leather **** to fit Lou's short stick
LS6 intake
Stock pedals/rubber pedal covers
Spohn tunnel brace
LG C5 brake conversion brackets
Strano sway bars
Long tube headers - stainless (Kooks, etc)
Poly motor mounts
HIDs
A pillars
TA door panels
stainless brake lines
catch can
Aluminum diff cover
All prices OBO unless otherwise noted, shipping extra, local only for now on big stuff. Paypal or cash. I check PMs once or twice a day. I will make good package deals, especially on interesting trades. Pics in next few days, can come see stuff in Katy.
Thanks,
Jason
A4 pedal assy.
A4 crossmember
factory torque arm
steel driveshaft
$500 for all
Also have now:
factory LCAs - $25
EGR - $20
$400
LS6 intake
Spohn tunnel brace
Strano sway bars
Poly motor mounts
HIDs
A pillars
TA door panels
catch can
Aluminum diff cover
Thanks,
Jason
