F14 ptv clearance
Old 01-30-2008, 02:57 PM
xfactor_pitbulls's Avatar
Default F14 ptv clearance
Putting this cam in my buddies car this weekend, and I am going mill the heads tomorrow. Safe to mill .030 with gm mls? I assume it is, just wanted to see if anyone has run it. 232/234 .598/.598 112+2. Intake duration leads me to believe there shouldnt be any problems.
Thanks
Brandon
Old 01-30-2008, 03:07 PM
LS1 Tech Administrator
Patrick G's Avatar
If the head has stock valve sizes, then you should be OK on P to V clearance. It will be tight, but that IVO is in a pretty safe area.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 01-30-2008, 03:55 PM
geovett's Avatar
Question
Thanks
Brandon
so, i have similar question, installing ms3 cam 237/242/606/609 lsa 113
also have ported and milled .030.. 2.02/1.57 castings #853's WHAT SIZE PUSH RODS DO I NEED, dang, i know lots a racers have gone this route, i can't get a good answer.........I need help!!!! i guess the only way is with lenght checker huh? ......can't afford better heads so.....poor man's budget..lol
Old 01-30-2008, 04:47 PM
7.350 should suit you just fine.
Patrick the heads have 2.02 valves, but you dont lose anything worth mentioning over the stock 2.00.
Thanks
Brandon
Old 02-02-2008, 06:07 PM
ssheets's Avatar
I'm running an F14 on 5.3 heads milled about .005" (60cc) So that's equivilant to 5.3 heads milled .035". I'm also running 2.02" intakes. I used a MLS .054" gasket. All said and done I have .100" intake clearance and .180" exhaust clearance. My pushrods are 7.450". Of course my valve train geometry is more like a 241 head milled .005"
If I take the heads off I will re-install with .040" Cometics and go for more compression.
Old 02-03-2008, 01:07 PM
PREDATOR-Z's Avatar
I would measure to be sure, it will be a bit tight on intake
