Formula for Displacement
Old 01-30-2008, 03:02 PM
Cobras_Rule's Avatar
Default Formula for Displacement
What is the formula needed to figure out the displacement of an engine.
I know i need bore and i know i need stroke...
what else?
Old 01-30-2008, 03:36 PM
LS1 Tech Veteran
Steve Bryant's Avatar
It's Pi (a constant equal to approximately 3.14) times the radius squared (half the diameter of the bore multiplied times itself) times the stroke times the number of cylinders. If the dimensions are in inches, the answer will be in cubic inches. Alternately, if you use centimeters, the answer will be in cubic centimeters.
So that's: Displacement = radius * radius * 3.14 * stroke * cylinders
I hope that this helps.
Steve
Old 01-30-2008, 05:17 PM
405HP_Z06's Avatar
or
.7853982 * bore squared * stroke * number of cylinders
Old 01-30-2008, 05:43 PM
Old SStroker's Avatar
Originally Posted by 405HP_Z06
or
Right. To make it easy to remember, use .7854, the four numbers in the upper left corner of a keypad/calculator run clockwise. It is PI/4 rounded a bit and is accurate to a small fraction of a cubic inch of displacement. Actually it it is accurate to about .0008 cubic inches in a 350 V8.
It just makes it easy. You don't even need to remember the exact number. It's on the keypad. That's handy for us older folks.
bore x bore x stroke x number of cylinders x .7854 = displacement
Jon
Old 01-30-2008, 05:49 PM
shoemike's Avatar
http://www.marcintology.com/tuning/b...kecylinder.xls
Old 01-30-2008, 05:59 PM
ok thx guys. thats what i needed
Old 01-30-2008, 11:37 PM
405HP_Z06's Avatar
Jon
