WTB LS1 short block
38K mile shortblock from a 2000 TA. Pulled engine immediately after hearing a very faint intermittent knock - possible worn or spun rod bearing. Comes with block, complete rotating assembly, cam and crank sensors, front cover, rear cover, and valley cover. There is no cam or lifters in it but I can include a stock 2001 cam and lifters if you like. None of the caps have been off. Piston and cylinder bores look good other than a lot of carbon on the piston tops.
$350 with the engine stand. I really do not want to ship. I'm located in MD.
