Sponsored by: DashLynx
HID Wiring question: 9004 bulbs
Old 02-01-2008, 08:42 PM
Tudds's Avatar
Default HID Wiring question: 9004 bulbs
This is for my Jeep but those guys are homos and told me to play with the wires until I found a way to make it work
I made this picture to explain it? Does the yellow go together? Is it just a ground? I really dont know about wires
Old 02-01-2008, 09:42 PM
Brian2006's Avatar
You have it correct. The extra wire hanging off is in case you want to physically ground it to a bolt or something. Just match up the two red wires of the factory harness and the HID wire.
Old 02-01-2008, 09:49 PM
Tudds's Avatar
They didnt work when I had them the red with red and black with black... blahhhhh I hate wires
Old 02-01-2008, 09:54 PM
Brian2006's Avatar
Well that extra wire is attached to the black one so I would assume that should be grounded. But then again I'm not exactly sure what your factory black with red wire is for?
Old 02-01-2008, 10:07 PM
Tudds's Avatar
I have no idea, So I should strip the dangly black and attach it to something metal? or try to stick it in that middle hole?
Old 02-01-2008, 10:09 PM
Brian2006's Avatar
Yes give that a try. Does the other one look the same?
Old 02-02-2008, 08:38 PM
Tudds's Avatar
The red wire went into the center one and they turned on, I let the extra black wire dangle.
Thanks for your help
