2000 F Body harness/LQ4 into 65 Chevelle.Who do you recommend for harness mods?
Just purchased a 2000 F Body engine harness(SEE ATT Photo)for my 65 Chevelle SS engine swap.Looking for recommendations on who to use for the harness modifications?
Details of swap are fresh rebuilt .020 over 2004 LQ4,using Y body front accessory drive,2000? Camaro stock intake,injectors,TB,MAP,IAC,97-98(peremeter bolt valve cover)coils with harness,200R4 transmission with TCI lock up harness.Battery is in the stock location.Planning on using Walbro 255? external fuel pum with Corvette fuel filter/regulator.Dougs long tube swap headers.
Would like to use front O2 sensors,eliminate ABS,Vats wiring and any other non-essential wires.Possibly extend harness(would like hidden/clean install with ECU under dash.
Any recommendations/input would be helpful.Thanks
