I Need Help Taking These Ugly Stripes Off My Car!!!!!
I have a pewter z with black stripes down it and I am desperately trying to get rid of the stripes so I can order a hood and get that and my new ss spoiler painted before summer. These ugly stripes I have seems to be like big stickers or big pieces of electrical tape really. But you catch my drift they are stuck on there with some type of adhesive. My question is should I use a heat gun or hair dryer because the heat gun would bubble the paint? Also they wont come off by just trying to pull them off. The just crack up and it would take years. Any help please!
I had the same problem. Your best bet is to use the heat gun and try and peel off as much as you can. This may sound crazy to you but this is the way i do it to take of vinyl stickers witht the heat gun. As you are heating it up you use your other hand and leave it around the area you are heating up its kind of hard to explain but you can use it as a temp gauge in other words to feel about how hot that area is. Dont leave it there too long or you will get burned, this is the way i heat up the area to the point that the addhesive is more forgiving. Then start peeling on the area where it is the hotest. After that i would use laquer thinner to take off glue residue. You have to be careful with the laquer because it makes your clear soft and makes it easy to scratch. Rubbing alcohol is easier to use but will take longer to take the resudue off.
