Drag wheels on a street/strip car???
Old 02-06-2008, 11:02 AM
CaMaRo67RS355's Avatar
Exclamation Drag wheels on a street/strip car???
ok guys well the more i play with my 02 SS the more extreme it comes. its no longer a DD but i do occasionally want to drive it to the beach which is like 3 hrs away or so... would i be safe driving on some welds or bogarts?
how many of you have drag rims that you drive around on???
Old 02-06-2008, 11:43 AM
roadhog_113's Avatar
i found a thread talking about how bogarts fall apart if drivin on the street. Search for bogarts street.
Old 02-06-2008, 01:00 PM
DopeFedZ's Avatar
Any big and little is not meant for street driving. Yes alot of people do it and I was one of those until one of my Welds developed a hairline crack along the lip. I've had it repaired and no longer drive with them on the street.
Old 02-06-2008, 01:20 PM
jjordan's Avatar
I am guessing DopeFed that you had a problem with a 3.5 front. These are not the best choice for a lot of reasons for any car that see's street use. If you can put a 15x5 on the front, you will like the way it handles, it is really hard to tell the difference in looks between the 3.5 and a 5", much better selection of tires AND can just about guarantee that the Weld Pro-Star will hold up with no problems.
Old 02-06-2008, 02:02 PM
DopeFedZ's Avatar
It was the rear 10" rim. The fronts are fine.
Old 02-06-2008, 02:14 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Common sense tells me that if the rims are for drag racing, they should be used for drag racing, and only that. Driving a car on the street puts loads on your suspension that you simply won't see driving a 1/4 mile at a time down pavement that doesn't have potholes and such...
I've seen lots of people drive on the street with drag racing rims. I've also heard lots of stories of those rims breaking over time...I don't care if you kill yourself because your drag wheels broke going down the street, but if you take out my car in the process...well, that's just dick.
Old 02-06-2008, 11:31 PM
well like me and 99% other younger guys dont have alotta cash to buy multiple sets of wheels. i was just seeing if it would work butsince they are known to crack i guess ill try to figure something else out.
