Notices
Need 99+ PCV System
Old 02-06-2008, 09:22 PM
Parrothead497's Avatar
Default Need 99+ PCV System
I need a driver's side valve cover hookup from a 99+ PCV system. Just the grommet that plugs into the valve cover.
Thank you
Last edited by Parrothead497; 02-06-2008 at 09:41 PM. Reason: Just need Valvecover connection
Old 02-06-2008, 11:05 PM
LS1W's Avatar
Default grommet
Thank you
the one that the pcv valve pushed into ?
Old 02-08-2008, 06:32 PM
I need the actual rubber grommet that is attached to the valvecover. I believe the PCV is pushed into it. Just need the rubber piece on the back of the drivers side valve cover. Anyone have this? Last part I need to complete my H/C swap.
