Lq4 parts interchange.....
What is swapable between an lq4 and other ls style engines(ls1,2,3,6 etc)
What about bottom end parts? Rod bolts from ls2?
Intake manifold from ls1,2, or 6?.....Best price and performance....
How much taller is the lq4 manifold as opposed to an ls6?
I hear lq4 is better for torque slightly less hp on top end.....
What about mls headgaskets?......I want a thick one....As thick as possible..
what size gasket and bolts studs should I use?
I hear the lq4 pistons are good till 550-600hp
Thats all I want ...leave stock or swap....Which low comp pistons are the best bang for the buck?.
Ok so I want to an lq4 swap.....
What exactly to I need to change to get it to an f-body spec?
What parts are interchangeable.....?????
Will a t56 bolt right up,????If not what do I have to do?......
I hear yes....I hear noo.....whats the deal?.....
I want to keep the iron block heads...But switch to ls6 style intake.....
Fi application of course//////
What exactly do I need to do to get this thing going?
Thcarguy84@live.com or pm me....
