Oil Pressure Gauge, A/F Ratio Help
Auto meter guage. how do i hook it up to read the oil pressure. its a manual one i heard u could go above the oil filter with some fitting from a vette??? is this right? i really dont wanna have to tap or anything into my block..
also havin issues with the a/f ratio guage too... what pin do i splice it into on the pcm
thanks!
thanks!
thanks!
thanks!
A/F ratio gauge gets tapped into the factory O2 for narrowband or runs a separate O2 for wideband.
Not sure why you are trying to wire it into the PCM.
Above the oil filter is a fitting and you tap into that with a 1/8" NPT tap, and then screw on your oil sending unit, run your copper line, and presto!
I think these will work for ya...
http://www.jegs.com/webapp/wcs/store...57617_-1_10625
Or splice into the purple wire.
