C clip eliminator?
C clip eliminator?
Just looking to beef up the old 10 bolt in my car. It doesn't get run hard but just for a little added insurance I was told a set of C clip eliminators help out quite a bit. Anyways would these work on an F-body? http://store.summitracing.com/partde...5&autoview=sku
Just went thru all this. Found out the hard way...C clip eliminators will NOT work with F bodies! Don't waste your time. I just ordered the correct eliminators...according to Summit. I found out that they wouldn't work after the axle tubes had already been cut and the eliminators were already pressed on to axles. I called Summit back and they insisted that these were the right eliminators for the 98 Trans Am. I called Moser and was told that they would not work with disc brakes. Noone stepped up to accept responsibility and I got stuck with a trashed housing.
