NARROWED REAR END. How Much ZR1 Clearance.
how much clearance is there on the inside of a wheelwell with a 9.5" zr1 that has a +56 offset?
long story: i have a 1"(each side) narrowed rear end going into the car. originally i wanted to get the 17x11's +50 in but i don't think it will work now.
now i want to get 18x9.5 wheels with a +56 offset. just checking to see how bad i effffed up on narrowing 1". i'm willing to use a spacer to bring the wheel back out some or even back to stock. the car is lowered and my intentions were to have the tires tucking without tubbing or touching the fender.
i have 20x8.5 with a +34 offset that were about 1/2" away from my fender, i didn't like that so i wanted a 1" narrowed rear end to bring the wheel in more. but now i want to go 9.5 or wider.
Basically with 1" narrow you will have to make up just over 25 millimeters. How about going with a 38mm 10.5 Z06? I think you would need around a 1/2" spacer with that.
BTW good choice with removing the 20's.
