Notices
where can find true duals??
Old 02-19-2008, 03:26 PM
wht98ls1's Avatar
Default where can find true duals??
i have a 98' z28 and wanted to know where i could find and buy a true dual exhaust??
Old 02-19-2008, 03:43 PM
Linden76football's Avatar
there is a place called texas speed that has a true dual exhaust for LS1 camaro's for about $460 heres the link http://www.texas-speed.com/shop/item...d=196&catid=56
Old 02-19-2008, 03:49 PM
wht98ls1's Avatar
damn there pretty expensive i was thinking they would be cheaper for some reason..........
Old 02-20-2008, 04:00 PM
well you can make your own using some smaller mufflers and a summit x pipe if you have long tubes you can ussually do a little work and get the x pipe to bolt right up to the collectors with just a little bit of welding and then most people run mufflers like dynomax bullets and then dump them right off the muffler here is an example from an LT1 site of how to install them.
http://www.lt1engine.com/techaids/trueduals.html
Old 02-20-2008, 11:29 PM
superssport's Avatar
I have some that will bolt right up to your manifolds. Where are you located?
Quick Reply: where can find true duals??
