brake bleeding question
So i had to do a ASR Relocation Kit on my car cause the ASR was in the way of the blower.. And now i need to bleed the brakes again but i have heard that you need to have dealer bleed em with a special tool.. Is that right? or can i just bleed em? And if so how i do it correctly?
you can do it. have someone inside the car pump the brakes three times and keep firm pressure on the pedal on the third pump. Then you open the bleeder screw while he pushes the pedal to the floor. close the screw right when the pedal hits the floor and have him lift off the pedal and have him pump the brakes 3 times again. open screw while the pedal goes to the floor. repeat unitl you see clean fluid come out. and keep an eye on the fluid level in the master cylinder
start with the rear brakes and work forward
Adding to the post above.
You want to put a hose (clear hose) on the bleeder and have the other end in a clear bottle with enough NEW brake fluid. During the procedure of pumping the brakes, make sure no more air is in the line. And since the tube will be in new fluid, it can't suck up air once the pedal is let go. Start in the rear first.
Oh and the "special tool" the dealer uses is just an automatic suction device that uses compressed air. You only need one person to do this unlike this procedure which takes two.
