how much hp will this set-up make?
can anyone help me out with how much hp this set up will make?? trying to decide wheather to build this or throw in an lt1...
1987 gta 350 tpi, bored .30 over
3.23 gears
10.3:1 compression
holley stealth ram intake with airfoil
comp xtreme enery hydraulic roller cam: 224/230 duration, 503/510 lift
hydraulic roller lifters
comp magnum roller rockers: 1.6 ratio
double roller timing chain
torque converter: ~2500 stall
3" flowmasters (thinking of changing)
Edelbrock shorty headers
might be getting heads
I was also wondering if anyone had some suggestions on good compatable heads and cam. im looking for around 350 hp with the above set-up. I really want a good sounding cam, but i have tpi so i dont think the lobe seperation should be less than 112 degrees.
Thanks a lot for any help!
3.23 gears
10.3:1 compression
does anyone have any recommendation on heads and the best size cam to go with them? im not looking to spend much more than 1000 on heads. i heard edelbrock heads are no good... true?
i've been using the brodix ik180's on 350's with great sucess,made over 450hp with them on a street 350 with flattops and a hyd roller,they cost around $1100.00,i'm a dealer for them,let me know if your interested.
i think ive decided to go with a 383. ill also be getting a roller cam (around 220 or 230 duration and around 530 lift), roller lifters and rocker arms, torque converter around 2500 stall, and heads. I am thinking about the brodix ik180's
